Install Individual Packages Missing
matthewa
1
Post by matthewa »
Hello
Back in February on 1.0.25 we were able to open the agent and install individual plugins, i took screenshots for a Wiki on how back then.
However, this feature seems to be missing on 1.0.26 and i am not sure why. We have removed LUM Plugin and the two database entries and reinstalled the LUM plugin but makes no difference, the right click and select option is no longer there.
Has this handy feature been removed or do we have another problem?
Matt
Re: Install Individual Packages Missing
I don't believe it was removed.... Let me go have a peek and see.
I am not seeing that function in the plugin currently, depending on how the function operated maybe there was a issue with it? I can not answer as I just don't remember that far back. :roll:
What I can do, is in the global view of agent, add a menu item to allow you to pass a package name to the end agent for direct install.
GIve me until noon or so, should have that punched out quick enough.
Here is build 1.0.27.
https://delivery.shopifyapps.com/-/ac68 ... a0b13b056b
Menu
Installer
matthewa
1
Post by matthewa »
That's brilliant! Works for us.
Many thanks Cubert :D
Glad to help!
