Help setting up - paid
fav-net
1
Post by fav-net »
Hey there,
we are having difficulties setting up chocolatey / Habitat.
I´ve basically installed the plugins but i can not get installations to work.
Is there someone who can help us setting up a basic structure and explain the best practise usage to me?
Best, Manuel
Re: Help setting up - paid
@fav-net
Chocolatey for Automate and Habitat's App Manager although cut from the same code are different products. Are you using Chocolatey For Automate or Habitat's App manager?
If your using Habitat then here is a link to a post with a quick video on how we setup App manager.
viewtopic.php?p=10318#p10318
If your using Chocolatey for Automate then you are in the right forums and I can help you here.
Post back here the product in use so we can get you accurate data on how to manage.
