New Install of 3.6 Missing Groups
matthewa
1
Post by matthewa »
Hello
I have installed 3.6.0.2 and do not see any Groups at all. This is a fresh install of Chocolatey for Automate, not an upgrade.
Anyone any ideas why the Groups may not have populated. I installed under my Super Admin account, have restarted the database etc.
Matt
Re: New Install of 3.6 Missing Groups
Really,
OK let me do some quick testing, get back to you in a few minutes
Ok we found the issue and resolved it, Some where between 3.6.0.1 and 3.6.0.2 a small block of code was removed. These 3 lines created the main search for the primary group. Since the plugin did not create this search entry into the database it could not later add a group that referenced this missing search.
My Apologies, I must of fat fingered that block during some edits. Since I already had that entry in the DB further testing worked as expected. This lead to the release of 3.6.0.2 with that bug in it.
Build 3.6.0.3 is now available, you can log in to portal and get it from the account management and subscriptions area or tonight the plugin should auto update to latest build, so tomorrow you would have new Groups and any missing table data needed to operate.
matthewa
1
Post by matthewa »
Brilliant! Many thanks for sorting this out, I have the groups now showing, thank you. :D
