For $7 dollars, Run a Chocolatey Cache Proxy for all clients under your MSP
Posted: Fri Oct 06, 2023 7:01 pm
You can connect to chocolatey.org to download public packages, internalize packages, and keep them for offline deployment by deploying a $7 dollar a month Cache Poxy.
Create_Chocolatey_CacheProxy_for_$7_amonth.pdf
(1.07 MiB) Downloaded 482 times
Avoid Rate Limiting from Chocolatey.org
Chocolatey.org has strict rate-limiting policies, which means you may start receiving that dreaded “429 error” in the middle of deploying or upgrade packages.
You can prevent these errors by caching Chocolatey packages in ProGet so that your package deployment will not be interrupted.
