Computer name available in View Alarms window
vjcsteve
Post by vjcsteve »
Can you add the computer name to the View Alarms pop-up window? The LAGM tab lists the computer name, but the Alarms window lists the computer's ID. It would be easier to compare if both windows referenced the computer using the same method.
Habitat reviewing LAGM changes.png (53.58 KiB) Viewed 18924 times
Re: Computer name available in View Alarms window
Yes we can fix that.
I have now updated the code base with this fix, it will be available in next release.
