Invalid SSL Certificate
reboot3times
Post by reboot3times »
I'm trying to load the ESX Health Monitor plugin but I'm running into this error (see attached). I've already updated to 5.0.0.4 and I cleared out the DLL files before restarting the Control Center. Can you let me know what I need to do here?
Screenshot 2023-03-06 164743.png (21.38 KiB) Viewed 5150 times
Thanks.
Re: Invalid SSL Certificate
Here is build 5.0.06
https://delivery.shopifyapps.com/-/6f70 ... bf78e4f3d1
Both build 5.0.0.4 and 5.0.0.6 should be using https://lp.plugins4automate.com and not lp.plugins4labtech.com.
Sounds like you have a older DLL hanging about somewhere. Try the updated zip here and restart the DBagent, restart the control center and see if that resolves issue.
