How to fully uninstall Habitatat plugin
danwg
Post by danwg »
Hello, my apologies if this is already covered somewhere. We are moving from Automate hosted to RMM and will not be able to use Habitat anymore. I am looking for instructions to uninstall Habitat from Automate.
Is this as simple as reversing the install instructions? Or are there other artifacts in Automate that should be cleaned up (db tables, files downloaded to agents, etc)? My primary concern is that I do not impact agent computers when cancelling the subscription.
Here is the install guide I referenced:
https://www.plugins4automate.com/pages/ ... to-labtech
Re: How to fully uninstall Habitatat plugin
Here is the answers you seek.
viewtopic.php?t=5794
We are sorry to see you go but if you are moving to CW-RMM then you might be interested in monitoring the following forum. There is a new tool on the horizon that will give you "Habitat" like tools for just about any RMM environment.
viewforum.php?f=95
