Upgrade notification
Posted: Mon Dec 12, 2022 4:31 pm
by ken@commonangle.com
Is there a way to customize the Windows upgrade notification popup? We would like to add a bit more information into this message and customize it for some target systems.
Re: Upgrade notification
Posted: Mon Dec 12, 2022 8:23 pm
Yes you can modify the Patch Remedy script located in the scripts/maintenance folder of your Automate console
Look for the line that asks for user input and modify as needed.
