Build 1.0.0.13 released
We have released the latest build 1.0.0.13 which resolves several issues with the terminal and adding Key protectors or refreshing data.
The biggest visible changes will be with the Terminal and how it works. The terminal does some validation now and if data is accurate and valid it exposes the execute button else it will return what issues it sees that would cause issues with terminal.
We also added a means to exit if an agent is not responding. Sometimes you send agents commands and they sit on them causing long waits. The new terminal will now pop up a request to wait or quit that you can select to exit if agent is not responding to task.
