Admon not collecting all machines
Admon is not collecting all computers, it's only showing computers where the admin account used in 'Deployment & Defaults' 'Login to use for Administrator Access' has logged into the endpoint and a profile folder has been created. Please see attached screenshot of the command output relating to the script. Any ideas?
- Screenshot 2022-06-10 155402.jpg (28.66 KiB) Viewed 8234 times
Re: Admon not collecting all machines
That is coming from the following line in the Admon script. Find this script in your "scripts/Maintenance/" folder in automate. Edit this line and change the Run as admin to Run as Local Agent and see if that resolves your issues.
Thank you, that appears to be populating more entires.
- 2
Just for reference, I had to make this adjustment as well, even after having confirmed my credentials were correct in Automate, it didn't want to collect the data.
I am running on-prem 2022.6.
Great Tool. Thanks for the efforts helping everyone.
The run as admin was a throw back to the LabTech 8/9 days when the agent was set to run as a user and not SYSTEM. So more people had issues running the tool outside of domain permissions and Windows 2003 Server did not have this user profile issue when running script.
The years have caused change but the baseline script is so simple it never really needed an update, and so this minor issue keeps rearing its head.
I will one day remember to update the script and push a new build out so this goes away.
