Mass Installer feature - Client Console
There is a Mass Installer button available as of build 3.5.0.7 that allows you to install any package from cache to one or more agents at the same time.
This button launches the following window where you can select any "caching" agent or agents from list and a software package and push to all agents select at one time.
If an agent is a stand-alone agent it will not show up in this list. The agents also must be enabled in the plugin else they will also be excluded from list.
Return to “ChocolateyForAutomate 3.5 Document Project”
