The data drive specified is not set to automatically unlock
bfalco
Post by bfalco »
I am getting this error on reboot of a system we enabled bitlocker on. One suggestion to get past the error is to not choose bitlocker check when manually enabling. Can we set that option through the plugin? Or do you of another way to get past this?
Re: The data drive specified is not set to automatically unlock
The plugin does not currently do this but it can, So I will go ahead and add that function to the drive options in plugin so you can execute the auto unlock enabler using plugin.
I will go ahead and add that in today and get a build release out asap.
See if this build helps,
https://delivery.shopifyapps.com/-/c15a ... cfd9f19d9b
You should now have a new "key protector" type at the bottom of list that "sets Auto Unlock"
So select an agents drive then select to create a new Key Protector, select from Key protectors to "Set Auto Unlock" and added that, It will launch terminal and execute the enable-BitlockerAutoUnlock -mountpoint "Drive Letter" on that agent.
You will have to already encrypted drive.
