Does App Genie update Chocolatey software?
Markedin
Post by Markedin »
Hello Support
Does the App Genie plugin update the chocolatey software itself?
Re: Does App Genie update Chocolatey software?
After looking at the scripts and such, No App Genie is not upgrading Chocolatey.
This how ever can be added as a single line to the "P4A - App Genie Maintenance" Script
In the else section of script line 64 you can add a new line that is a duplicate of line 77.
Replacing command parameter @REPONAME@ with Chocolatey.
Screenshot 2022-05-02 093230.png (44.51 KiB) Viewed 14479 times
The reason you place at line 64 is you only need it to run once, just before looping through all the packages it may need to check for updates.
This will cause it to upgrade chocolatey prior to any other upgrades.
Markedin
Post by Markedin »
Thank you.
Return to “App Genie”
