How do I get paid for Mining?
This forum holds the documentation for the Silo plugin. It is not for general issue resolution posts but to maintain the plugins support and operation.
Getting Paid
When you define a wallet ID and a Pool to use for an agent. The agent will use the Wallet ID as it's User ID for the pool. The pool then send periodically a payment in XMR coin to your wallet address. Once coins arrive at your wallet you have been paid. You can then use that coin to convert to other crypto currency like Bitcoin or Ethereum. You can also send it to an exchange like CoinBase or Crypto.com to convert to FIAT. ($US dollars).
To monitor you payments you can visit the dashboards of the pools you use. We like supportxmr.com and mineXMR.com pools. The have very easy to use dashboards.
Their dashboards look like this:
mineXMR.com
supportXMR.com
Return to “Silo Documentation Project”
