Device Dashboard
Device Dashboard
Get Device Stats
Get direct access to vital device stats on a regular interval. Use this data in Automate monitors, data views, alarms and ticketing.
Access pfSense Web Configurator
From the device main dashboard you can access the web configurator of the device at the client's location in just seconds. A SOCKS tunnel is created between the 2 agent IDs. The agent ID of a Windows PC at the client's location picked at random (well almost, some weight given to OS version) and your local agent's ID. This means you must also be a part of your ConnectWise Automate environment for the proxy controls in ConnectWise Automate to function.
