Debug mode
This forum contains the documentation for the Bitlocker for Automate plugin
Debug mode
If you are having real issues with the plugin and need to have more detailed information on the failures. You can enter debug mode which will present any failure from the plugin to the user in the form of pop up message boxes. You will get different notices of operation, warnings or errors as you traverse the plugin.
To turn on debug: Hold down CTRL key while clicking the BitLocker logo at the top left corner of plugin.
To turn off debug: Hold down SHIFT key while clicking the BitLocker logo at the top left corner of plugin.
Return to “BitLocker Documentation Project”
