Print Report
Print Report
This is our first step into printing charts, data views and images. There is a lot to expand on here as we continue to grow the plugin.
You currently do not have any control over your printer selections, it defaults to your default printer. If you want it to generate a PDF file you will need to set the PDF file creator as the default printer before printing reports from plugin.
Here is a sample PDF of both the Client report and Agent report.
Client Report
client-p4a.pdf
(74.12 KiB) Downloaded 361 times
Agent Report
agent-p4a.pdf
(89.18 KiB) Downloaded 325 times
