Client Console View
Posted: Fri Jan 07, 2022 7:46 pm
The Windows Defender plugin allows you to manager the preferences and settings for Windows Defender. Monitor the status of Windows Defender and take action when needed.
The Management of Windows Defender is done in the client console as a tab called Windows Defender. From the view you can see the status of any agent that has been successfully scanned by the plugins maintenance script. This script is automated and should run every 4 hours starting at 4 am and ending at 8 pm. Agents must be online for schedule to be created. Offline agents are skipped. Get daily alarm statuses for all your agents and across your clients.
The preference tab of the agent view allows you to manage all the preferences for that agent. There is a menu provided at this view that allows you to control Windows Defender directly without user disruption.
These menu items are:
  • Push preferences to agent
- Allows you to make changes to the behavior of Defender.
  • Quick Scan Agent
- Pushes a quick scan down to local windows defender
  • Full Scan Agent
- Pushes a full scan down to agent
  • Remove Active Threats
- Has Defender remove all active threats.
  • Update Signatures
Updates the Defenders signatures
  • Offline Scan
- Forces agent to reboot and preform a scan during the bootup process.
  • View Threats
- Displays the list of active threats found on any agent.
Manage Defender View allows you to see in real time how the agent is responding to the different Defender commands being sent.
Re: Client Console View
Posted: Fri Jan 07, 2022 7:51 pm
Here is the difference between a good View and A bad View
The Good View
All agents are reporting all good.
The Bad View
Several agents reporting disabled services and settings
By using the Defender For Automate plugin you can turn Bad to Good with just a few clicks, never disturbing the end user .
