BitLocker for ConnectWise Automate is here
Client Console Tab(Main Control)
In the main console you can visualize the clients BitLocker environment. Control each agent directly from the main control area.
  • Enable BitLocker on Drives
  • Add New Protectors
  • Suspend BitLocker
  • Lock A Drive Down
  • Disable BitLocker
  • Push Backup to Active Directory
By default we store any passwords, pin codes and recovery passwords in Automate and are able to query any agent for the current recovery passwords if they exist.
Our automation collects and keeps current all data about BitLocker and the volumes it is protecting daily.
Add a new Protector
You can add any protector you like to the agents volumes by selecting the correct protector and providing the information need by that protector.
