Build 3.0.0.8 released
Support and discussion forums for the Plugins4Automate Office365 for ConnectWise plugin.
Man we blew through a few builds their as I was working with a MSP to resolve several bugs in the system.
Well we captured a lot of them and fixed a lot of stuff.
If you haven't you should upgrade to Build 3.0.0.8 + as soon as possible. The service may auto update you depending on your current version. If not you will need to manually download plugin from www.pluginsforautomate.com and update your plugin.
You should also follow the following post to fix your MSOL events collection if that area is blank or missing in your plugin currently. If you have MSOL event data in your plugin then the table fix is already done and your good.
viewtopic.php?f=65&t=5904&sid=1437e764f ... d604e047df
Return to “Office365 For Automate”
