DROP All SQL Tables for Habitat
DROP TABLE IF EXISTS `plugin_p4a_habitat_agent_status`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_announce_maintenance`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_announce_maintenance_logs`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_app_manage_agent_apps`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_app_manage_assoc`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_app_manage_clients`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_app_manage_enable`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_app_manage_update_log`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_automation`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_agent_lastlog`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_clients`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_config`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_events`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_found`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_history`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_history_archive`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_jobs`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_shadows`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_backup_windows_sync`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_brew_packages`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_brew_status`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_brew_taps`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_commands`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_drive_files`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_expiry_configure`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_expiry_email`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_functions_list`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_ghostfile_client_files`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_ghostfile_files`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_groups`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_lagm_alerts`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_lagm_config`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_lagm_monitor`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_lagm_users`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_lum_packages`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_lum_status`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_maxosx_config`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_maxosx_updates`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_patchmatic_client_config`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_patchmatic_kb`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_patchmatic_kb_installed`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_patchmatic_status`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_powershell_cmds`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_powershell_config`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_powershell_dotnet_versions`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_powershell_scripts`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_powershell_versions`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_printerstatus_agent`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_printerstatus_clients`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_properties`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_safety_scans`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_serverlogs`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_wifiscan_devices`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_wifiscan_networks`;
DROP TABLE IF EXISTS `plugin_p4a_habitat_win10upgrades_agents`;
