Printer Status License Error
reboot3times
Post by reboot3times »
Just installed the Printer Status plugin and am receiving the below error message when clicking on the tab.
Below is text output of the log file:
LTAgent  v210.132	 - 8/11/2021 12:04:00 AM	 - Plugin PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: PrinterStatus ISync auto upgrade, checking for new versions:::
LTAgent  v210.132	 - 8/11/2021 12:04:00 AM	 - Plugin PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: PrinterStatus ISync Squid sync our version is (1.0.4) and the available version is (0.1.0.3):::
LTAgent  v210.132	 - 8/11/2021 12:04:00 AM	 - Plugin PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: PrinterStatus ISync is current:::
LTAgent  v210.132	 - 8/11/2021 12:04:00 AM	 - Plugin PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: PrinterStatus ISync auto upgrade completed:::
LTAgent  v210.132	 - 8/11/2021 12:27:33 AM	 - Plugin PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: PrinterStatus ISync auto upgrade, checking for new versions:::
LTAgent  v210.132	 - 8/11/2021 12:27:33 AM	 - Plugin PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: PrinterStatus ISync Squid sync our version is (1.0.4) and the available version is (0.1.0.3):::
LTAgent  v210.132	 - 8/11/2021 12:27:33 AM	 - Plugin PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: PrinterStatus ISync is current:::
LTAgent  v210.132	 - 8/11/2021 12:27:33 AM	 - Plugin PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: PrinterStatus ISync auto upgrade completed:::
And the errors file:
LTAgent  v210.132	 - 8/10/2021 12:05:40 PM	 - Plugin Error PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: SetSQLYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1:::
LTAgent  v210.132	 - 8/10/2021 4:05:56 PM	 - Plugin Error PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: SetSQLYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1:::
LTAgent  v210.132	 - 8/10/2021 8:00:41 PM	 - Plugin Error PrinterStatus, Version=0.1.0.4, Culture=neutral, PublicKeyToken=null: SetSQLYou have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1:::
Re: Printer Status License Error
I just looked at license code and the call needed updating. We now have it pointed to the correct license services in 1.0.5
https://delivery.shopifyapps.com/-/b656 ... 0921c0a5eb
Return to “Printer Status Plugin”
