Habitat 1.0.0.73 and the new PatchMatic Windows Patching tool
Posted: Fri May 07, 2021 5:06 pm
Habitat PatchMatic Windows KB Patch Manager is a new tool that allows you to distribute Windows Hotfixes to any agent automatically across the RMM environment. Make out of band patching (patches not detected by existing agents or some Microsoft Optional patches) quick and easy.
This tool was requested by Jeff Brock when he asked if there was a plugins or otherwise, that will allow an Automate system to download and install specific KB’s that are not in the Patch Manager to specific clients, locations, or machines based on the detected OS?
Thanks Jeff for the request, what a cool idea.
Document Project
viewtopic.php?f=64&t=5860&sid=c1701a88d ... 8310e1c5d5
Re: Habitat 1.0.0.73 and the new PatchMatic Windows Patching tool
Posted: Fri Jul 09, 2021 2:36 pm
by ccalverley
Doesn't work, Doesn't Scan.
Posted: Mon Jul 12, 2021 2:15 pm
In the Automate Host plugin logs for Habitat you should see the following when Automation runs .
LTAgent v210.82 - 7/11/2021 8:01:31 AM - Plugin Habitat, Version=1.0.0.77, Culture=neutral, PublicKeyToken=null: Habitat PatchMatic Operations starting.:::
LTAgent v210.82 - 7/11/2021 8:01:31 AM - Plugin Habitat, Version=1.0.0.77, Culture=neutral, PublicKeyToken=null: Habitat Operations (PatchMatic) Started.:::
LTAgent v210.82 - 7/11/2021 8:01:31 AM - Plugin Habitat, Version=1.0.0.77, Culture=neutral, PublicKeyToken=null: Habitat Operations (PatchMatic) Installs scripted for [0] Locations.:::
LTAgent v210.82 - 7/11/2021 8:01:31 AM - Plugin Habitat, Version=1.0.0.77, Culture=neutral, PublicKeyToken=null: Habitat PatchMatic Operations completed.:::
It should show location attempts when a schedule is present.
Posted: Tue Jul 13, 2021 6:20 pm
by JvdMaat
You've got some labels swapped ;)
2021-07-13 14_19_07-Window.png (5.17 KiB) Viewed 6773 times
Posted: Mon Jul 19, 2021 1:14 pm
Oh Gees... Thanks
Posted: Thu Aug 12, 2021 3:38 pm
This is now fixed in 1.0.0.79 due out by this weekend
