Access Google Drive
dand724
Access Google Drive
Post by dand724 »
We are new to Habitat, trying to configure Google Drive, but when we click on it in Control Center nothing happens. Everything else seems to be work correctly.
We are on the latest Automate build. Can someone point us in the right directions so we can get this worksing.
Thanks, for the help.
Re: Access Google Drive
So you are not seeing this window pop up?
Try running the Automate control center "run as administrator" and retry the plugin access to this feature.
This feature requires plugin to copy the google drive API dll files to your locate PC so it can talk to google. This could be failing under your user permissions. This would only need to be run like this once to allow dll downloads.
See if that helps.
