Auto-Install Cycles Failing
Posted: Fri Apr 23, 2021 4:18 pm
by aaroncampbell72
Labtech logs only show "Failed to login user"
Re: Auto-Install Cycles Failing
Posted: Mon Apr 26, 2021 1:01 pm
If you are using packages set to install "As Admin" in the plugin configs then this may happen.
The As Admin setting expects that you have all the credentials setup for the client in the client configs so that when the LTscript pulls the "admin" user/pass there is something there for it to use that will work on agent.
Otherwise when not checking that box it will use the default user the agent runs as which in most cases is SYSTEM which has all rights needed.
If your packages is set to use "As Admin" then remove and re-add package with out that setting set. Allow it to run again and see if it now installs and expected.
