Habitat UI Issues - Cannot See Bottom of List
whooper
Post by whooper »
I apologize if this has been reported before, but I found it hard to search the forum for non common keywords to describe it.
In the Habitat Map Drive Viewer and the Habitat Local Administrators Group Monitor tabs, the bottom of the table is cut off by the "Save/Cancel" bar. Resizing the window or adjusting the DPI settings (I usually run at 125%) doesn't seem to help.
Any thoughts?
Automate version 2020.8
Habitat version 1.0.0.67
Re: Habitat UI Issues - Cannot See Bottom of List
We do see that. It looks to be a product of the Windows form expanding.
We have reconfigured these to panels and it should be correctly working in the next build
1.0.0.68
Thanks for pointing that out.
You should now see 1.0.0.69 as a version installed on MSP hosts, This should now work as expected ,,please let us know if you see any other UI issues?
