Habitat Upgrade Assistant - Robocopy & MountDiskImage errors?
sirkerry
Post by sirkerry »
Are the MountDiskImage and Robocopy supposed to be throwing missing parameter errors?
Mounted ISO as Drive letter [ Mount-DiskImage : Missing an argument for parameter 'ImagePath'. Specify a parameter of type 'System.String[]' and try ]
ROBOCOPY Returned -> [ -------------------------------------------------------------------------------
ROBOCOPY :: Robust File Copy for Windows
Started : Thursday, April 8, 2021 10:50:31 PM
Source - C:\WINDOWS\system32\Mount-DiskImage\
Dest - C:\WINDOWS\system32\:\
Files : Missing
an
argument
for
parameter
'ImagePath'.
Specify
a
parameter
of
type
'System.String[]'
and
try
Options : /DCOPY:DA /COPY:DAT /R:1000000 /W:30
ERROR : Invalid Parameter #17 : ":\"
Simple Usage :: ROBOCOPY source destination /MIR
source :: Source Directory (drive:\path or \\server\share\path).
destination :: Destination Dir (drive:\path or \\server\share\path).
/MIR :: Mirror a complete directory tree.
For more usage information run ROBOCOPY /?
**** /MIR can DELETE files as well as copy them ! ]
Dismount Drive Returned -> [ -------------------------------------------------------------------------------
Files : Missing
an
argument
for
parameter
'ImagePath'.
Specify
a
parameter
of
type
'System.String[]'
and
try
Re: Habitat Upgrade Assistant - Robocopy & MountDiskImage errors?
Can you post a copy of your policy here so we can see what you have configured?
sirkerry
Post by sirkerry »
Here you go:
First minor issue that overall should not cause issues but could. The Web URL should end without the "/" on the end. Other wise you may get at http(s)://weburl//webfile instead of a http(s)://weburl/webfile
Next, It looks like Robo Copy didn't get passed accurate information.
We should first test to see if ISO was successfully downloaded to
C:\windows\ltsvc\Habitat\Windows10UG\xxx.iso on the local agent?
Can you mount ISO and see files inside ISO manually?
The script then attempts to mount it and create a drive letter for it. Then runs robo copy to copy files from ISO drive to local drive.
So if robo copy is failing then ISO may be issue where mount failed.
If ISO was missing you should of received an error in script logs and it fail out before running robo copy.
So I suspect it had to do with a mount issue . Check the script logs during the process and post them up here. I suspect there maybe a issue when executing the mount command.
This will show up in the commands logs during script execution.
Post both command and script logs return messages here for review.
