New in Habitat 1.0.0.67
Posted: Thu Apr 08, 2021 6:47 pm
Most of the work in this build was done to Windows backups Services.
We changed the one configuration for all clients to each client now has it own settings.
This means you can scan client #1 every hour and client #2 every 8 hours and client C can have its override on and that client will run at the set time all independent of each other.
We added a new automated function called "Push backup is late or missing". This checkbox turns on this function, which will during the set scan cycles, test the agents current backups to see how stale it is. If the last backup is over 36 hours old the function will attempt a manual backup based on the saved setting from your backup schedule. This has been a big help with several Windows boxes that keep stopping the daily backups. The manual seems to go through just fine.
We added several new menu items to the main agent list view,
You now can see all recovery points the agent is reporting and the last Windows Backup log file content.
We also cleaned up the automation some making it a bit faster and streamline.
Lots of goodies in the Backup Windows tool.
