Initial setup wrong?
automatedummy
Post by automatedummy »
Hey guys I have a new site setup with Chocolatey for automate. I have the apps in the main Chocolatey and then I have the site that I want set to enable. I selected the apps but none seem to auto install the location is also set to enable, what am I missing it has to be easy.
Re: Initial setup wrong?
Did you get a chance to review the videos and guides?
Chocolatey for Automate
https://youtu.be/kuWdFHBPV0A
Document Project - https://lp.plugins4labtech.com/helpfile ... roject.pdf
Chocolatey For LabTech
https://youtu.be/la4334g9zNA
Quick Start Guide https://www.plugins4automate.com/pages/ ... tart-guide
automatedummy
Looks like it is all set right. Is there a way to speed the timer up instead of 12-24 hours?
Which plugin are you using? If C4A then no, C4L does allow more control over automation.
