Duplicate Script GUIDs
rshaw.golden
Post by rshaw.golden »
I was looking into a Solution center issue, which was throwing an error trying to work with an Alert Template due to duplicate Script GUIDs. Once I prodded the database into spitting out which ones they were, there turned out to be two for us - and both involved Habitat.
Screenshot 2021-03-15 111617.png (36.64 KiB) Viewed 5130 times
We used to have the standalone Admon plugin, and Habitat has its own version there - but they both have the same script GUID.
Both of the Stalled Agent Detector scripts reference Habitat in the description, but the one without Habitat in the name is older. If I look at the description in Automate it lists:
Date12/04/2019
Version 1.0.0.17
I'm going to see if I can remove the two older scripts safely on my end, but wanted to let you know in case there's some check that needs to be added to make sure it doesn't happen in the future when Habitat installs or self-updates.
Re: Duplicate Script GUIDs
This is fixed in build 1.0.0.64 due out in tonight's updates.
rshaw.golden
Just a head's up that another duplication has popped up.
Screenshot 2021-04-02 141419.png (12.06 KiB) Viewed 4870 times
Ah missed one, will be fixed in 1.0.0.66 due out soon
We have released 1.0.0.66 today with this fixed in it. Let us know if you see any new issues.
