No Matches Found!
aavex_marlon
No Matches Found!
Post by aavex_marlon »
We just jumped from Chocolatey for Labtech to Chocolatey for Automate Unlimited Agents. Now I'm trying to add a package for the for GoogleChrome but and several packages, but it fails and says "No Matches Found". Chocolatey has been installed on the tech PC as well as our LT Server but still fails. What could be the problem and solution to this? Please see screenshot Thank you.
TeeEm
Re: No Matches Found!
Post by TeeEm »
Just try googlechrome on its own no install commands.
What he said,
Only use package name and not the full install command.
ilyak
Post by ilyak »
How can I add zoom-outlook ?
Ah sometimes case sensitive kicks in.
Try "Zoom-Outlook"
ilyak
Post by ilyak »
Thanks, that worked. Damn case sensitive package names :evil:
When we search for a package we are using the "LIST" function in Chocolatey to query for package. Even thou the Chocolatey.org site shows all lower case as the command to execute, when you use the LIST function it may or may not be the same way.
Take Firefox, chocolatey.org says its "firefox" and that will work just fine during install but if you want to match what's in the Repo list it maybe a little different. So to see if it is just execute
choco list firefox
and you should receive a list like below. Use the way it is spelled here to define your search in the plugin.
