Cylance & PoSh Scripts
sirkerry
Post by sirkerry »
Cylance is killing the PoSh scripts from Habitat that run on workstations, any chance y'all can change these over to signed scripts so we can have Cylance whitelist them?
Re: Cylance & PoSh Scripts
I don't know enough about cert signing to just go off and do that.
What little I do know says for that to work I would need a public cert which would need to be purchased and incorporated in to scripts. I will look in to what it takes to do this.
sirkerry
Post by sirkerry »
Apparently a way around this is to have the PowerShell script as a .ps1 file in the LTshare instead of creating it on the fly by the script, then it's possible to check the checksum/hash of the .ps1 file against what is on the LTshare that Cylance knows about and have it allow the PoSh script to run (or so I've been told).
