Habitat LT Script Manager
Habitat Automate Script Manager
Description:
This tool allows the engineer to quickly see what scripts are available and if they are in a locked state. You can use the manager to remove, lock or unlock scripts.
NOTE: In order to edit locked scripts, they will need to be unlocked. This tool allows you to unlock locked scripts. You can lock scripts to prevent others from editing your scripts.
edward.cossett
Re: Habitat LT Script Manager
Post by edward.cossett »
Seems that the LastRun date for me atleast is sorting by month, then day, then year. Could this be changed to sort by year, month, then day so that it would truly be sorting the date in order. It's a nice tool that would help us clean up scripts. Thanks!
sure let me go set that
