The Windows Registry Search tool allows you to search the registry of any Windows agent under a client in real time. You can select to search one agent or all agents at a location, for workstations and or server. Quickly find which agents have a given key value or sets of data in keys.
- WindowsRegistrySearch.PNG (78.66 KiB) Viewed 15309 times
Select the Root Key to search and place in the sub key to find.
Example:
\SYSTEM\CurrentControlSet\Services\LTService
