Cannot remove approved application from global list
aaroncampbell72
Post by aaroncampbell72 »
I accidentally added an Approved Application for Good Chrome without giving it an Application name, Source Repository, or Repo Username. When I double-click on it to remove it, nothing happens. Is there an .xml or .config file somewhere on my hosted repository I need to edit to remove it from the Global list of Approved Applications?
Re: Cannot remove approved application from global list
can you post a screen shot? Not sure how that would happen.
aaroncampbell72
Ok see if this helps.
Find the apps in SQL
SELECT * FROM plugin_sw_chocolateyii_approved_apps WHERE AppCMD = 'Google-Chrome'
Delete the App with no title
DELETE FROM plugin_sw_chocolateyii_approved_apps WHERE AppCMD = 'Google-Chrome' and (Application = '' or Application IS NULL)
