Released Build 2.2.8
We just released build 2.2.8 which adds in auto update support for plugin.
You will no longer need to check versions and update plugin manually as it will now do that automatically.
You can get the latest builds by logging into your accounts and downloading the new updates. Once installed you should not have to do it again.
