Habitat Linux Update Manager
P4A has added an updated version of their popular LUM plugin into Habitat.
LUM or Linux Update Manager is a plugin designed to manage the patching process of the OS and applications installed on Linux systems that support either YUM, Apt-Get or Zypper. RedHat Linux, CentOS Linux, Debian Linux, Ubuntu Linux and OpenSUSE Linux patching has been left behind in the world of ConnectWise Automate but Plugins4Automate has a solution for you.
LUM Global Console View
This view allows for package management across all clients at one time. You can set the plugin to automatically install updates agents show available. You can exclude linux agents by selecting the EDF checkbox provided at the agent console.
Agent Console View
Manage agents individually with the agent console. At the agent console you can force a quick scan, install a single update or select to install all updates manually.
Exclude Agent from automatic updates
Each linux agent has an installed EDF checkbox available to it. When selected it will be excluded from the plugin auto updating the agents OS and application with updates.
Re: Habitat Linux Update Manager
New feature added for Debian Style Linux distributions
Apt-Get is used to update the core packages installed on Ubuntu but it does not update kernel packages with the standard upgrade commands. In the past Linux admins were very sketchy to update kernels via automation incase something went wrong so we removed the action during our upgrade process. Linux has matured to a level that stability and operation of major distributions is pretty much expected now. We have had requests to add this back in as a controlled feature are adding apt-get dist-upgrade back into Debian Style Linux management inside the plugin.
All systems that use Apt-Get will now have a new optional checkbox to Allow Distro Updates . This control adds the dist-upgrade command to the update all function. This function is used in automated updates and in the button to update all packages inside the plugin.
You can select this feature on a per agent bases making kernel updates an agent by agent choice.
This feature requires a reboot of the Linux system to complete updates. This reboot is automated and will happen after the updates are successfully installed.
frankbe
Debian Shows no updates
Post by frankbe »
Debian systems show no Updates
Is there a solution for this problem ?
We added a new feature in build 1.0.1.26 of Habitat that adds a control to manage when Linux updates happen globally.
Available options are:
Daily at 12 AM,
Weekly (pic a day) at 12 am
Monthly(pic a day) at 12 am.
This will be the schedule default for all Linux systems across Automate when Auto Updates are enabled.
chris10385
2
Post by chris10385 »
Is it possible to have a feature added where we can Export the list of updates? Some of our clients would like that info and right now our only option is to screenshot everything.
That is possible. I'll look at it and see what I can do.
RW10000
Post by RW10000 »
Does the RB "dot" mean they need a reboot FIRST? Or that after the patching they will need a reboot?
Is the schedule getting an overhaul in the new version?
e.g. it would be nice to group certain Linux machines at separate times/reboot cycles.
The red and green dots refer to what is now and current. If red, the agent needs a reboot reguardless of patch status.
