Habitat Mapped Drive Viewer Tool
In the Habitat Mapped Drive Tool we have added some new features. One of these new features is the ability to map a drive across a client to all agents under that client. You can also map drives 1 to 1 using the same tools.
See video of tool Here
You will find the main Mapped Drives Viewer under the Client Consoles of each client.
Click into the view to pull up menu to map a drive. Using the interface provided fill out the information needed and select Map It. Allow several minutes for the mappings to take place.
