Plugin Not Showing in Plugin Manager
Posted: Fri Dec 13, 2019 4:16 pm
by xtrasyrup
I removed and reinstalled the plugin to try and resolve an issue probably shouldn't have). After I reinstalled it, it would show up twice under Tools. I have since removed it and it's missing from Plugin Manager but still shows up under tools. Any ideas on how to fix before I try to install it again?
Patch Remedy .png (621.6 KiB) Viewed 22123 times
Re: Plugin Not Showing in Plugin Manager
Posted: Mon Dec 16, 2019 1:35 pm
Yeap, you hit the CW plugin update (bug).
They (CW) will call it a feature but IMHO it's a bug.
See the following post
viewtopic.php?f=55&t=5521&sid=01e650658 ... 588e40236b
