Windows Upgrade Assistant Explained
Posted: Fri Oct 25, 2019 1:23 pm
Habitat Plugin - Windows Upgrade Assistant
This tool allows you to push Windows 10 and Windows 11 update out to agents via automation.
You can schedule silent updates of Windows 10 by selecting 1 or more agents from agent list and then selecting to Scheduled Windows Upgrade. You can Upgrade Windows 10 to Windows 11 in a run now function.
This will verify that agent is windows 10 and that user is logged in to accept Windows 11 EULA. Once user accepts the update completes silently.
Windows 10 to Windows 10 upgrades do not require user to be logged in.
Screenshot 2022-10-02 123617.png (47.22 KiB) Viewed 2781 times
Re: Windows Upgrade Assistant Explained
Posted: Mon Apr 28, 2025 11:49 pm
by tmorton@gcti.com
This post was made Oct 2019. Are the updated instructions with different ways to do the update from Windows 10 to Windows 11, like for example disabling the prerequisite checks, do not download an updates, no having to have a user logged in to accept the update?
