Installation on single machine
pbosak
Post by pbosak »
Is possible to install apps on single machine ?
If i select check box 'install' or 'update' for workstations or servers - application will install unattended.
But how to install application on one machine from computer control? there is no option.
JvdMaat
Re: Installation on single machine
Post by JvdMaat »
I second this request. Especially in the initial testing phase, I'd like to not just blanket rollout a new app to all systems.
Is there any way to do a more granular install?
That is partly the differences between Chocolaty for Automate and Chocolaty for LabTech.
Automate is meant to be more simplistic where Labtech gave you every option and provided that granularity.
JvdMaat
Post by JvdMaat »
The per machine license doesn't work for us with 3000 agents out there.
I've partially worked around this by letting the plugin deal with the chocolatey deployment and reporting, and wrote a script that just runs the choco install <app> command.
But that's a workaround.
