Old apps from Poll
pbosak
Old apps from Poll
Post by pbosak »
Hello
I installed plugin and setup poll, but in left corner i have: last update [error] and all apps are terrible old (from 2017)
Schedule for repository update is enabled and running. What else i have to do?
cheers
pbosak
Re: Old apps from Poll
Post by pbosak »
hi, update passed but apps are still old (eq. Firefox v55)
Can you post a screenshot of your setup in plugin and the current data views it shows. This will gives us some perspective on what your seeing.
pbosak
Post by pbosak »
Hello
I disabled 'pooling' and add apps manually. That's enough for me.
We update this feature, now no longer requires LT server as an agent for scanning. Also adds new features to Automate scripting.
Have a peek at 3.0.0.32, plugins should auto update.
New Repo scanner setup
You now can add and remove the scanner deployment and send deployment to any agent ID you want. This fixes issues with Hosted RMM not having access to repo scanners.
