Disable by Location or PC
Locked
DomoB90
Post by DomoB90 »
Hi there,
Is it possible to make a feature request? I would like to be able to disable SurfLog by location or by PC. Right now I can disable it by client or altogether via the kill switch but I am finding that my clients have specific computers they don’t want tracked. If I could disable it for certain machines or by location that would be great. If this feature already exists please let me know. I wasn’t able to find it.
Best,
Dominick
Re: Disable by Location or PC
Dom,
This is already in there.
Open up a computer console and select the surflog plugin.
Across the top will be buttons, the first should be exclude. Once selected it will stop polling data for that system.
DomoB90
Post by DomoB90 »
WOW. Sorry, somehow I missed that. Thank you!
Best,
Dominick
:D
Locked
