Bug or Intended Result?
Locked
DomoB90
Post by DomoB90 »
Hi there,
Sorry to be a bother. I just got my first set of data in and when I click refresh it shows a duplicate of that data. If I continue to click refresh it will show another duplicate as many times as I refresh it. These duplicates disappear after closing the Client window. Is this a bug or is this intentional?
Before Refresh
Before Refresh
Before Refresh
After Refresh
After Refresh
After Refresh
Re: Bug or Intended Result?
Nope thats a bug, Let me look at refresh as it should be reloading data not adding to current data.
DomoB90
Post by DomoB90 »
Thanks for checking! It seems to be only the graphs that are affected as far as I can tell. The Top 50 Sites isn't getting duplicated I believe when clicking Refresh.
Locked
