Autofix 0x80240025 option won't stay ticked
Posted: Wed Aug 14, 2019 9:58 pm
by Moza
The autofix 0x80240025 option won't stay ticked after saving.
Fix anyone?
Thanks,
Re: Autofix 0x80240025 option won't stay ticked
Posted: Thu Aug 15, 2019 2:19 am
by Webgroot
I am also having the same issue, as well as the master switch not staying on or the clear pushed staying on.
Posted: Tue Aug 20, 2019 12:14 pm
If you have a master button issue where it will not show (on) after a new install of the plugin. Reboot the LTHost server. This will cause a full database maintenance and refresh which will fix the button issue.
The buttons are working, just that the LTHost cached the off image used to show status and can not display the on image. The act of the DB maintenance resolves the issue.
As for the check box, I will look in to that and see if there is an issue.
Posted: Tue Aug 20, 2019 2:06 pm
We have released a new build 1.0.4.42 that has fixed this issue
https://delivery.shopifyapps.com/-/9678 ... 1d6b553b1a
Auto update should update your plugin sometime in the next 24 hours.
Posted: Tue Aug 20, 2019 5:09 pm
by Moza
Thanks Cubert,
I will give it a blast.
Posted: Wed Aug 21, 2019 5:03 pm
by Moza
Confirmed working, thanks!
