Support for Automate 2019
Locked
lalberts
Post by lalberts »
Hi there, I'm interested in the Surflog Browsing Metrics plugin. Is it supported on Automate 2019, or do you know if any partners are successfully using it on this version?
Thanks!
Re: Support for Automate 2019
Surflog is supported in all versions of LabTech and Automate.
Locked
