I'm getting an error on all agents when I try to use the "Clear and attempt LT Agent Service Using ScreenConnect" command. The error is "Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index"
Any ideas on how to fix this?
iternalnetworks
- 10
- stalled agent error.PNG (12.1 KiB) Viewed 14508 times
iternalnetworks
- 10
Re: Index was out of range.
After a little more digging I figured out my issue. Hopefully this will help someone else.
The ScreenConnnect plugin RMM+ had been removed in our ScreenConnect instance. Once I went into ScreenConnect and reinstalled the plugin and setup the password in both ScreenConnect and the Stalled Agent plugin, it now works.
