Does App Genie work with hosted Automate
connectsys
Post by connectsys »
Hi there
Can you tell me if I can use this on a cloud hosted Automate deployment please?
Also, sorry to be a pedant but in the "Installed Application Maintenance" screenshot you have in the "App Genie 1.0.0 Overview" you have Agents Effected and Apps Effected. Not sure if you have changed it since but it should be Affected not Effected.
Thanks in advance
Ollie
Re: Does App Genie work with hosted Automate
Lol yes, our dev team had a battle over the effect versus affect
Affect is usually a verb, and it means to impact or change. Effect is usually a noun, an effect is the result of a change.
So is the plugin "Affecting" the software titles or is it and "Effect" of the App Search?
Currently we have as effect, as a engineer, english being my second language to machine language I will have to take your word on that. We are not adverse to change if that's the correct usage.
As for on Prem and Hosted, Works the same for both! Just follow the install instructions here
https://www.plugins4labtech.com/pages/h ... to-labtech
connectsys
Thanks for the prompt response Cubert! I have to say that even native speakers struggle with that occasionally, I have to correct co-workers now and again ;) Please rest assured though that affected is the correct usage in this case.
Thanks a lot for the info, looking forward to trying it out. Is the cost shown a flat monthly rate?
Ollie
Return to “App Genie”
