Automate Tickets
netservicesgroup
Automate Tickets
Post by netservicesgroup »
Does the plugin create a ticket in Automate that I can attach to a client? And if so, how?
Re: Automate Tickets
Yes it will, Just turn it on.
netservicesgroup
Is there a way to customize the ticket contents to include the details of a successful cleaning run?
Sure can,
Find the CCleaner Maintenance script in your scripts list. Inside the script you will find a "ticketing" area that you can modify so that tickets say whatever you like them to say.
