If Plugins Fails To Open
If after installing a plugin and relaunching the LT console you do not get the plugin to open it maybe because your missing some devexpress DLL files that should be in the LT client install folder but are not.
To verify this open the LT console client error log file and see if after an attempt to launch plugin you get errors in this file saying that a DevExpress library could not be initiated.
If so copy the following Zip down to the local desktop running LT client and place files in LTclient install folder. Relaunch the console and that should resolve it.
Http://lp.plugins4automate.com/files/De ... s-12.2.zip
BruceG
Re: If Plugins Fails To Open
Post by BruceG »
Do we copy the entire Zip or just the files that are missing, Cubert?
Copy all libs missing from folder that are in the zip
http://lp.plugins4automate.com/files/De ... s-12.2.zip
and if you still have issues, use the installer below to set the windows environment up correctly, choose 30 day demo when asked for license.
http://lp.plugins4automate.com/files/DX ... 2.2.17.zip
JosefNT
Post by JosefNT »
I have replaced the missing files from the zip, but I am still unable to open Patch Remedy. When I click the second link to download the installer, I get a CONNECTION_RESET error.
The DevExpress site doesn't appear to offer the same trial install (at least not in that version), so I'm not sure where else to look for the installer to finish correcting my environment.
jenniferjones
Post by jenniferjones »
If Patch Remedy still fails after copying DLLs, check the client error log again: it should show whether the DevExpress load error persists or has changed. Also confirm the DLLs are unblocked, match the app’s bitness, and sit in the same folder as the LT client executable, not a subfolder. A connection reset on the installer link often means the host is blocking the download or the file is gone; ask vendor support for the exact DevExpress 12.2 environment installer or a current replacement rather than relying on the public trial.
